uite aicea specificatii si cum se leaga,Mariane se poate monta in caz ca nu are ceasurile de la voltmetru si ulei ,acolo ar fi perfect
Pin
Colour
Function
Connects to
1
White/Green
Tail or Dipped beam failure
Ground
2
Brown/Blue
Coolant Level Switch
Ground
3
Blue/Red
Engine Oil Level Switch
Ground
4
Black/Yellow
Stop Light Fuse
12V Ignition
5
Black
Fuse 7
Black on TID/DID Loom
Brown
Ground
Brown on TID/DID Loom
Brown/White
Diagnostic
Optional, Diagnostic Pin G
Brown/Red
Diagnostic
Optional, Diagnostic Pin D
Brown/White
Reset Button
Stalk (Stalk Common to ground)
Brown/Red
Set Button
Blue/Black
Fuel Tank Sender
Back of Instrument Cluster, Left Hand connector
Blue/Red
Speed Signal
Transfer wire & pin from TID Connector
Black/Brown
Fuel signal
See Table Below
Blue
Outside Temperature
Blue/White
Outside Temperature
Yellow/Red
Brake pad wear sensors
Ground
Brown/Yellow
Washer fluid level Switch
Ground
Black/Yellow
Stop Light Lamps
Leave Disconnected
Black connector
Pin
Colour
Function
1
Red 12V
2
Blue Outside temp - Transfer to Blue connector
3
Brown Ground
4
Blue/White Outside temp - Transfer to Blue connector
5
Black Ignition
6
Grey/Green
Instrument Illumination
7
Grey/Black
Instrument dimmer
8
Red/Grey
Radio
9
Brown/White
Radio
10
Brown/White
Radio
11
Brown/White
Radio
12
Blue/Red
Speed Signal - Transfer to Blue connector
ECU/Engine Type
Fuel Signal Pin on Engine ECU
MFD Program No. (Pulses per km)
C14NZ / C16NZ
A2
2 (8892/8850), 82 (16665)
C14SE / C16SE / X16SZ / 16LZ2 / C18NZ
B4
X14XE / X16XEL / X16SZR
B12
C20NE M1.5.2 / 18SE M1.5.4
32
9 (8892/8850), 89 (16665)
C18XE S56 / X20XEV S56.1
14
66 (16665)
X18XE / X20XEV S56.5
21
C20XE M2.5 32 16 (8892)
C20XE M2.8
15
50 (8850), 114 (16111)
*C25XE M2.8 (Cavalier/Calibra)
17
*C20LET M2.7 (Cavalier/Calibra)
32
*X25XE M2.8.3 (Vectra)
47
* These Engine/ECU combination will not have a Factory MID program.
If you want to do a proper job.
Obtain a Diag connector from a Cavalier, and remove one of the contacts.
Join this to a brown/red wire, and insert it in Location D of the Astra Diag connector in the fuse box (lever up the retaining clip that pushes in from the top)
Connect this Brown/Red to the one on the MFD loom.
Connect the Brown/White from the MFD to th brown/white wires coming from Pin G of the Diag plug.
You can now reprogram the MFD with Tech1,
